Dump ".fsdb" in modelsim NT version?
cyc
how to dump fsdb in modelsim
I am trying the modelsim55x NT version. The dump file in ".VCD" might be a large file. Does anyone know how to dump ".fsdb" in modelsim NT version?
fsdb dump modelsim
add "-pli novas.dll" to vsim
novas.dllmodelsim
You can find how to use pli function $fsdbdump in debussy help document. You can compile and link the dll file using the source files provided by debussy.
creating fsdb files in modelsim
You need to modify the modelsim.ini file
to add a line like this:
Veriuser = novas.dll
Also you need to set LD_LIBRARY_PATH to
point to the novas.dll file.
modelsim libpli.dll
Using the Visual C to compile the veriuser.c and modelsim PLI together to get the novas.dll
fsdb version
if you use debussy version is less than 5.2, you can copy debussy/share/pli/nc/libpli.dll to /verilog/tools/bin and copy pli.lib to /verilog/lib. new you can use fsdbDumpfile and fsdbDumpvars to dump fsdb data directly.
If you don't need to use additional PLI, you are supposed to be able
to use the included novas.dll to dump fsdb file. Look for the document
in your installation.
debussy fsdbdump
You may want to take a look at the link below
SAHO
