dump file format of cadence ncsim
raki08
Newbie level 2
bangalore
ncsim dump file format
Hi frenz,
I need to know the dump file format of cadence ncsim ..as i have to use the results to tabulate and check the conditions of i/o..can any one help me out with this..
thanx,
raki
Cadence, like other vendor, has their own proprietary format, so you won't be able to use any other tool (e.g. text editor) to view their file (it's in a binary form by the way). However, Cadence, like other vendors, also support the open format VCD, which is in a text file.
For your purpose, it's probabl alot simpler to just capture the info in your Verilog file and output the data of every cycle to a text file yourself. This way you know exactly the format.
For example:
module A (
input
input abc;
ouptut xyz;
always @(posedge clk) begin
// output abc, XYZ to text file, along with time (see Verilog manual for I/O command
    raki08
