quantized
Member level 2
- Joined
- Jul 6, 2012
- Messages
- 51
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,887
Question: is it an ESD risk to have an NFET with its gate grounded even when its drain is grounded too?
Argh!
I've just finished up a layout for a tech where the minimum diffusion separation (i.e. minimum STI width) is much larger than the minimum contacted gate pitch. This means you can improve density by putting a "dummy gate" between nearby unconnected diffusion regions. I did this with the NFETs in the latches/registers; there are tons of them so the improvement was substantial (10-15%). In all instances where I did this at least one of the diffusion regions was already grounded to begin with; the other one is an unrelated signal node.
Unfortunately, days from tapeout, I discovered that the foundry advises against this due to ESD risk -- the gate is connected directly to the GND pin. The GND pads have ESD protection (diodes and some other foundry magic) but the foundry advises that supply-connected gates should have a 2kohm resistor inline as well. They don't say if this still applies when the NFET with a grounded gate also has a grounded source. I'm having trouble seeing how ESD damage would occur in this situation, but I'm not an ESD expert.
Is this something I need to worry about? Unfortunately there is definitely no room in the layout to bring in an additional "resistive GND" supply to every single latch.
If this is bad practice, why doesn't it apply to MOSCAPs used for decoupling? Those have their gates tied to VDD, which seems like it would be even worse.
Thanks,
Here's an example of the layout, Mead-Conway color scheme (pink poly, green diffusion, blue Metal-1). The ground node is labeled, as is the node "x" which is some unrelated node. Simply deleting the ggNMOS is a DRC violation since the grounded diffusion contact would be too close to the contact for node "x". Node "z" is the gate of a nearby (unrelated) pulldown NFET for node "y".
Argh!
Thanks,
