Dual Voltage power supply
gfactor
Junior Member level 1
Lagos, Nigeria
dual voltage power supply
Pls Anybody with a circuit on dual voltage power supply which is 12v by 5v
like the one for a PC CD ROM drive
circuit dual voltage power supply
If you are really intrested to buld one, you may use circuits from the datasheets of LM7812, 7805, 7912 etc. If you are aiming to drive a CDrom drive externally, the real best choice is the PC smps supply which will supply what you need and it will be cheaper than the one constructed. Good luck
dual power supply
Thanks, but do you have any circuit in hand
dual voltage power supply circuit
If you are building, download some datasheets. Or you'll get a PC smps reday to use. Good luck
