wccheng
Full Member level 5
upconversion mixer simulation spectrerf
Dear all,
I am doing dual up conversion mixer simulation using SpectreRF simulator. However, I do not know the setting of NF and voltage gain simulation. I hope you could give me a step for reference. My simulation input is as follow:
RF input: DC with a band from 0 ~ 250MHz (the RF input signal is DC and up converted to the required frequency range)
LO1: 1.3GHz
LO2: 2.1GHz
The upconverted frequency is 3.4GHz
At the same time, I attached the schematic of the two up conversion mixers connection and source generation. I use two ports and VCVS to generate the quadrature output for RF and LO1. How could I select in the pnoise (Input Source) and the pxf selection in order to get a correct result?
Thanks
wccheng
Dear all,
LO1: 1.3GHz
LO2: 2.1GHz
Thanks
wccheng
