cupoftea
Advanced Member level 6
This is a Interleaved dual BCM PFC chip. (FAN9611)
Surely this is a waste of time?
On the first page of the datasheet it should say.............
1...Cannot be (cheaply & realistically) used with powder core inductors
2...Needs two Gapped_core/bobbin/clamp sets to be assembled for the 2 boost inductors (with all the associated assembly costs)
3....Needs two gapped cores for the ferrite cores which are a pain to source and are more expensive with long lead times.
So, Both stages need an auxiliary coil on the inductor to indicate the zero crossing.
This means powder core torroids cannot realistically be used (due to coupling concerns) , and a full gapped-core/bobbin/clamp set
needs to be used.
This makes the product assembly more awkward, and it is simpler to use two Powder-core ACM_CCM Boost PFC stages
in parallel with each having 2 current sense transformers to reconstruct the ground return current.
They can be sync'd to be interleave switching.
A simple share circuit on the output will assure equal current sharing.
Not to mention that any design with gapped cores is more awkward and expensive to kit for than one
where there are no gapped magnetics.
One could use the UCC28070 dual ACM_CCM controller but every one i ever ordered arrived with snapped off
pins or ESD damage....so two sync'd ACM_CCM PFC controllers with total of 4 current sense transformers
is the way to go. A current sense transformer is extremely simple to wind...can be done on a small split bobbin
with pri in one section and sec in the other.
The sharing circuitry for the paralleled ACM_CCM Boost PFCs can comprise one stage with
divider regulating it to 410V....the other to 390V...then an error amp pulls current through an extra upper divider resistor
(in the "390v" stage)to equalise the output currents
of each booster.
needs to be used.
of each booster.
