Shahar Levi
Newbie level 5
- Joined
- Apr 6, 2014
- Messages
- 9
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 3
- Activity points
- 110
For a school project I need to design a signal generator which generates digital touch-tone-signals (DTMF) with duration of 60-70 ms that can be used in DTMF-telephony. the signals later will be fed to the on-board existing Digital-to-Analog converter and then to the exisiting on-board AC97 audio codec.
I have spent long hours on researching after implementation ideas but I am still very confused about the right direction.
I know I need to generate overall 8 different frequencies and each DTMF tone must contain one sinusoid from the high- frequency group (1209, 1336, 1477 and 1633 Hz) and one sinusoid from the low frequency group (697, 770, 852 and 941 Hz).
How do I design it with VHDL code? should I use the principle of NCO (numerically controlled Oscillator) and use LUT for each frequency? if so, what size of LUT should I create? 20 samples dhould be enough? is there a better approach to implement this?
I would very much appreciate any idea or an hint or even better, VHDL code which could help me out here.
Thank you in advance,
