Dspic33f + LCD 4x20(mode 4bit) + check busy flag....... help me
trinhdieuhvktqs
Newbie level 2
hello everybody !
I'm writing program display lcd 20x4, mode 4bit , used busy flag before communicating with lcd and not used Delay. I wrote according to the datasheet of lcd but not displayed at all. please help me
#include <p33FJ64MC802.h>
#include <math.h>
	_FGS(GCP_OFF & GWRP_OFF);
	_FOSCSEL(FNOSC_FRCPLL);
	_FOSC(FCKSM_CSECMD & OSCIOFNC_ON & POSCMD_NONE);
	_FWDT(FWDTEN_OFF);
	_FICD(ICS_PGD1 & JTAGEN_OFF);
    #define  Fcy           		40000000     			//Instruction Cycle Frequency
    #define  BAUDRATE       	9600
#define LED_READ    LATAbits.LATA0
#define LED_BLUE   LATAbits.LATA1
#define LCD_RS LATBbits.LATB15
#define LCD_RW LATBbits.LATB14
#define LCD_E  LATBbits.LATB13
#define	LCD_D4  LATBbits.LATB10
#define	LCD_D5  LATBbits.LATB9
#define	LCD_D6  LATBbits.LATB6
#define	LCD_D7  LATBbits.LATB7
#define LCD_1_D7  PORTBbits.RB7
// DINH NGHIA CAC CHE DO HOAT DONG CUA LCD
#define	LCD_clear	0x01		//Xoa man hinh LCD
#define	LCD_home	0x02		//Tro ve dau dong
#define	LCD_normal	0x06		//Che do nhap du lieu binh thuong
#define	LCD_normal_s	0x07	//Che do nhap du lieu binh thuong, dich man hinh
#define	LCD_off 	0x08		//Tat man hinh
#define	LCD_on	 	0x0C		//Bat man hinh
#define	LCD_on_crsr 0x0E		//Bat man hinh va con tro
#define	LCD_on_blink 0x0F		//Bat man hinh va con tro (nhap nhay)
#define	LCD_4b2l	0x28		//Che do 2 dong, giao tiep 4 bit du lieu
#define	LCD_homeL1	0x80		//Ve dau dong 1
#define	LCD_homeL2	0xC0		//Ve dau dong 2
#define lcd_line_two 0x40
unsigned long TM1,TM0;
unsigned int i;
long int EC;
void InitPort(void);
void Timer1_Init(void);
void OSOC_Init(void);
void Delay_us(unsigned int time);
void Delay_ms1(unsigned int time)  ;
void Timer2_Init(void);
void Init_LCD(void);
void LCD_OK(void);
void LCD_CMD(unsigned char cmd);
void LCD_DATA (unsigned char dat);
void lcd_putstr(char *buffer);
void lcd_gotoxy(int x, int y);
void khoi_tao(void);
void LCD_IN_INTER(unsigned int d);
void LCD_IN_FLOAT(float d);
void LCD_busy();
int main (void)
OSOC_Init();
InitPort();
Timer1_Init();
Timer2_Init();
Init_LCD();
Delay_ms1(100);
lcd_gotoxy(4,1);
lcd_putstr("weather station");
LED_DO=1;
while(1)
		if(IFS0bits.T2IF==1)
		 TM0++;
		   if(TM0==1000)
			  {LED_BLUE^=1;
				TM0=0;
		IFS0bits.T2IF=0;
return 0;
void InitPort(void)
 //LATB  = 0x0000;			// Initialize Port-B
      PMD1=0xffff;
      PMD2=0xffff;
      PMD3=0xffff;
     TRISAbits.TRISA0 =  0;
    TRISAbits.TRISA1 = 0;
   TRISBbits.TRISB10 = 0;   			//LCD_D4
   TRISBbits.TRISB9 = 0;   				//LCD_D5
   TRISBbits.TRISB6 = 0;				//LCD_D6
   TRISBbits.TRISB7 = 0;				//LCD_D7
   TRISBbits.TRISB15 = 0;				//LCD_RS
   TRISBbits.TRISB14 = 0;				//LCD_RW
   TRISBbits.TRISB13 = 0;				//LCD_E
LCD_D4=0;
LCD_D5=0;
LCD_D6=0;
LCD_D7=0;
LCD_RW=0;
LCD_RS=0;
LCD_E=0;
//Config FCy=40MHz
	    PLLFBD=41;					// M=43
	    CLKDIVbits.PLLPOST=0;		// N2=2
	    CLKDIVbits.PLLPRE=0;		// N1=2
	    OSCTUN=0;
// Disable Watch Dog Timer
	      RCONbits.SWDTEN=0;					// N1=2
		__builtin_write_OSCCONH(0x01);
		__builtin_write_OSCCONL(0x01);
		while(OSCCONbits.COSC != 0b001);		// Wait for PLL to lock
		while(OSCCONbits.LOCK!=1) {};
void Init_LCD(void)
    LCD_CMD(0x33);
    Delay_ms1(10);
    LCD_CMD(0x33);
    Delay_us(200);
    LCD_CMD(0x33);
    Delay_us(100);
	LCD_CMD(0x28);     //  che do giao tiep 4 bit 2 dong
    Delay_ms1(10);
	LCD_CMD(0x08);				// off man hinh
	Delay_ms1(10);
	LCD_CMD(LCD_normal);				//Tat man hinh
	Delay_ms1(10);
	LCD_CMD(LCD_on);
	Delay_ms1(10);
	LCD_CMD(0x01);				//Xoa man hinh
	Delay_ms1(10);
void LCD_OK(void)
//unsigned u;
LCD_E = 1; //Tao xung Enable
Delay_us(2);
LCD_E = 0;
//---------chuong trinh xuat lenh che do 4 bit--------------------------------------------------------------------------------
unsigned temp1;
LCD_busy();
LCD_RW = 0;
LCD_RS = 0; //Dat che do xuat lenh
temp1 = cmd >> 4; //Lay 4 bit cao
LCD_D4 = temp1 & 1; //Xuat 4 bit cao
LCD_D5 = (temp1 & 2) >>1;
LCD_D6 = (temp1 & 4) >>2;
LCD_D7 = (temp1 & 8) >>3;
LCD_OK();
temp1 = cmd & 0x0F; //Lay 4 bit thap
LCD_D4 = temp1 & 1; //Xuat 4 bit thap
LCD_OK();
//----------Chuong trinh con ghi mot ky tu o che do 4 bit--------------------------
unsigned temp2;
LCD_busy();
LCD_RW = 0;
LCD_RS = 1; //Dat che do xuat du lieu
temp2 = dat >> 4; //Lay 4 bit cao
LCD_D4 = temp2 & 1; //Xuat 4 bit cao
LCD_D5 = (temp2 & 2) >>1;
LCD_D6 = (temp2 & 4) >>2;
LCD_D7 = (temp2 & 8) >>3;
LCD_OK();
temp2 = dat & 0x0F; //Lay 4 bit thap
LCD_D4 = temp2 & 1; //Xuat 4 bit thap
LCD_OK();
//-----------Chuong trinh con hien thi 1 chuoi ky tu--------------------------------------------------------------------
    while(*buffer != '\0')
        LCD_DATA(*buffer); 	/* calling another function */
                                /* to write each char to the lcd module */
        buffer++;
       //Delay_us(50);
//-----------Chuong trinh con nhay den cot x, dong y-------------------------------------------------------------------
   int address = 0x00;
	switch(y) {
	case 1 : address=0x00;break;
	case 2 : address=0x40;break;
	case 3 : address=0x14;break;
	case 4 : address=0x54;break;
 	address +=x-1;
	LCD_CMD(0x80|address);
   // Delay_us(5);
	unsigned  i,j,k,l;
	l=d/1000;//nghin
	k=(d%1000)/100;//tram
	j=((d%1000)%100)/10;//chuc
	i=((d%1000)%100)%10;//donvi
	LCD_DATA(0x30+l);
	LCD_DATA(0x30+k);
	LCD_DATA(0x30+j);
	LCD_DATA(0x30+i);
// ========khoi tao timer 2
					PMD1bits.T2MD		=	0;					// Enable Timer1 module
					T2CONbits.TON 		=	0;					// Disable Timer
					T2CONbits.TCS 		=	0;					// Select Internal Clock for Timer1
					T2CONbits.TGATE 	=	0;					// Disable Gated Timer Mode
					T2CONbits.TCKPS 	=	0b00; 				// Set Timer1 Prescaler = 1:1
					TMR2 				= 	0x00;				// Clear Timer1 counter
					PR2 				= 	40000;				// 20ms period for keyboard detect	;3125
					//IPC0bits.T1IP 		= 	0x01;				// Timer1 interrupt Priority Level 1
					IFS0bits.T2IF 		= 	0;					// Clear Timer1 Interrupt Flag
					IEC0bits.T2IE 		=	0;					// Diasble Timer1 Interrupt
					T2CONbits.TON 		=	1;					// Enable Timer1
//----- khoi tao timer1---------------------------------------------------------------------
PMD1bits.T1MD      =   0;   // Enable Timer1 module
T1CONbits.TON = 0; // Disable Timer
T1CONbits.TCS = 0; // Select internal instruction cycle clock
T1CONbits.TGATE = 0; // Disable Gated Timer mode
TMR1 = 0x00; // Clear timer register
IFS0bits.T1IF = 0; // Clear Timer1 Interrupt Flag
IEC0bits.T1IE = 0; // Enable Timer1 interrupt
T1CONbits.TON = 1; // Start Timer
//------ham tao tre 1us (khi PR1=40)-------------------------------------------
	T1CONbits.TCKPS = 0b00; 	// Set Timer1 Prescaler = 1:1
	PR1 = 40*time ;					// Timer1 period set
   	while(IFS0bits.T1IF==0);		// While the interupt flag is not set
    IFS0bits.T1IF = 0;
//------ham tao tre 1ms (khi PR1=625) t?o tre toi da 100ms-------------------------------------------
{   T1CONbits.TCKPS = 0b10; 	// Set Timer1 Prescaler = 64:1
	PR1 = 625*time ;					// Timer1 period set
    IFS0bits.T1IF = 0;
//====== kiem tra co ban cua lcd============================================
void LCD_busy()
{    TRISBbits.TRISB7 = 1;				//LCD_D7  : luc nay D7 la chan vao
     LCD_D7   = 1;           //Make D7th bit of LCD as i/p
     LCD_E   = 1;           //Make port pin as o/p
     LCD_RS   = 0;           //Selected command register
     LCD_RW   = 1;           //We are reading
     while(LCD_1_D7){          //read busy flag again and again till it becomes 0
		   LCD_E   = 0;     //Enable H->L
           LCD_E   = 1;
THANK YOU VERY MUCH.
Thanks for your interest Jayanth.devarayanadurga my question. But you do not fully understand my questions.
if communication with lcd without checking the busy flag, use delay to wait for lcd processed. I did it. perhaps the send command and data 4bit mode I ok. but now I want to check the busy flag of the LCD do not use any more delay. Can you help me check function LCD_busy() and its proper place in my code ?
thank you very much !
Refer to LCD busy flag example in the 8051, PIC, or AVR books by Muhammed Ali Mazidi. You will get an idea of how to use busy flag. You will need 3 control pins.
