I have succesfully done PWM and ADC in the past 2 days and now wanted to do PWM interrupts. I have also successfully done external interrupts using INT0. I wrote the following code for PWM duty cycle control and doing A to D conversions within the PWM1 interrupt (this is just to test PWM interrupt).
I keep getting the following error while building :
PWM Interrupt.c: In function 'main':
PWM Interrupt.c:65:12: error: expected identifier or '(' before '.' token
PWM Interrupt.c:66:10: error: expected identifier or '(' before '.' token
PWM Interrupt.c:67:9: error: expected identifier or '(' before '.' token
PWM Interrupt.c:68:9: error: expected identifier or '(' before '.' token
make[2]: *** [build/default/production/PWM Interrupt.o] Error 255
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
nbproject/Makefile-default.mk:94: recipe for target 'build/default/production/PWM Interrupt.o' failed
make[2]: Leaving directory 'C:/Users/Chinu/MPLABXProjects/PWM Interrupt.X'
nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Users/Chinu/MPLABXProjects/PWM Interrupt.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
BUILD FAILED (exit value 2, total time: 625ms)
The code is given below:
Code C - [expand] |
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
| #include <xc.h>
#include"PWM Interrupt Config.h"
#include<libpic30.h>
#include<hspwm.h>
volatile float ADCValue;
void initAdc1(void);
int main()
// Configure PLL prescaler, PLL postscaler, PLL divisor
PLLFBD=54; // M=56
CLKDIVbits.PLLPOST=0; // N2=2
CLKDIVbits.PLLPRE=0; // N1=2
// Initiate Clock Switch to Primary Oscillator with PLL (NOSC=0b011)
__builtin_write_OSCCONH(0x03);
__builtin_write_OSCCONL(OSCCON | 0x01);
// Wait for Clock switch to occur
while (OSCCONbits.COSC!= 0b011);
// Wait for PLL to lock
while (OSCCONbits.LOCK!= 1);
INTCON2bits.GIE = 1;
initAdc1();
/*PWM CONFIGURATION*/
/* Set PWM Periods on PHASEx Registers */
PHASE1 = 5000; //For PWM Freq 14kHz @ 140MHz Fosc
PHASE2 = 5000;
PHASE3 = 5000;
/* Set Duty Cycles */
PDC1 = 0;
PDC2 = 300;
PDC3 = 200;
/* Set Dead Time Values */
/* DTRx Registers are ignored in this mode */
DTR1 = DTR2 = DTR3 = 0;
ALTDTR1 = ALTDTR2 = ALTDTR3 = 100; //For 720ns dead time at 140MHz Fosc
/* Set PWM Mode to Complementary */
IOCON1 = IOCON2 = IOCON3 = 0xC000;
/* Set Independent Time Bases, Center-Aligned mode and
Independent Duty Cycles */
PWMCON1 = 0x0604;
PWMCON2 = PWMCON3 = 0x0204;
/* Configure Faults */
FCLCON1 = FCLCON2 = FCLCON3 = 0x0003;
/* 1:1 Prescaler */
PTCON2 = 0x0000;
/*Interrupts Config*/
TRIG1 = 0;
TRGCON1 = 0;
TRGCON1BITS.TRGSTRT = 4; This and the next 3 lines are highlighted by the error message
IPC23BITS.PWM1IP = 4;
IFS5BITS.PWM1IF = 0;
IEC5BITS.PWM1IE = 1;
/* Enable PWM Module */
PTCON = 0x8000;
while(1)
void __attribute__((__interrupt__,no_auto_psv)) _PWMInterrupt()
//ISR Code here
AD1CON1bits.SAMP = 1;// Start sampling
__delay_us(10);// Wait for sampling time (10 us)
AD1CON1bits.SAMP = 0;// Start the conversion
while (!AD1CON1bits.DONE);// Wait for the conversion to complete
ADCValue = ADC1BUF0;// Read the ADC conversion result}
ADCValue = (ADCValue/1023)*5000;
PDC1 = ADCValue;
IFS5bits.PWM1IF = 0; //Clear Flag for next interrupt
void initAdc1(void)
{/* Set port configuration */
ANSELA = 0x0000;
ANSELBbits.ANSB2 = 1;// Ensure AN4/RB4 is analog
/* Initialize and enable ADC module */
AD1CON1 = 0x0000;
AD1CON2 = 0x0000;
AD1CON3 = 0x000F;
AD1CON4 = 0x0000;
AD1CHS0 = 0x0004;
AD1CHS123 = 0x0000;
AD1CSSH = 0x0000;
AD1CSSL = 0x0000;
AD1CON1bits.ADON = 1;
__delay_us(20);
What could be the issue?
