#include <p33fj64gp802.h>
// I/O definitions
#define CSEE _RB12 // select line for Serial EEPROM
#define TCSEE _TRISB12 // tris control for CSEE pin
// peripheral configurations
#define SPI_MASTER 0x0120 // select 8-bit master mode, CKE=1, CKP =0
#define SPI_ENABLE 0x8000 // enable SPI port, clear status
// 25LC256 Serial EEPROM commands
#define SEE_WRSR 1 // write status register
#define SEE_WRITE 2 // write command
#define SEE_READ 3 // read command
#define SEE_WDI 4 // write disable
#define SEE_STAT 5 // read status register
#define SEE_WEN 6 // write enable
// send one byte of data and receive one back at the same time
int writeSPI2( int i)
SPI2BUF = i; // write to buffer for TX
while( !SPI2STATbits.SPIRBF); // wait for transfer to complete
return SPI2BUF; // read the received value
}//writeSPI2
int main()
int i;
// 1. init the SPI peripheral
TCSEE = 0; // make SSEE pin output
CSEE = 1; // de-select the Serial EEPROM
SPI2CON1 = SPI_MASTER; // select mode
SPI2STAT = SPI_ENABLE; // enable the peripheral
// 2. main loop
while( 1)
// 2.1 send a Write Enable command
CSEE = 0; // select the Serial EEPROM
writeSPI2( SEE_WEN); // write enable command
CSEE = 1; // deselect to complete the command
// 2.2 Check the Serial EEPROM status
writeSPI2( SEE_STAT); // send a READ STATUS COMMAND
i = writeSPI2( 0); // send/receive
CSEE = 1; // deselect to terminate command
} // main loop
return 0;
} // main
