DSK6711: McBSP1 Tx to McBSP0
silver_sparrow
Member level 1
North Silicon Valley
pcm3010 project
Hi all,
I am a newbie at the DSK6711.
I can't seem to get the McBSP1 transmit to McBSP0 on the same
C6711DSK board through hardwiring the J2 connector in the following
fashion.
DX1 -> DR0
CLKX1 -> CLKR0
FSR1 -> FSR0
Where: McBSP1 will send the synch pulse & clock then data.
McBSP0 only receive clock and frame synch for the single phase frame
transfer
My Objective:
I need to do this to familiarize myself and verify the port and
experiment with different data formats/rates for school project
purposes, where I will use another board of some sort to transfer
data to my DSK6711 in the future.
Code I am using:
SPRA488B April 2002-McBSP Initialization <-I modified this code
So after reading the TI configuration I am a bit confused on:
*If I have the configuration correct for both McBSP ports
*If the max clock for the McBSP is 50MHz[undivided]
*My theory of port synchronization
Also, I am not confident my code is correct.
Would someone kindly voluteer to take a quick glance at the short
annotated code for me plz? I included the project just in case.
Thanking you in advance
Sparrow
silver_sparrow
Member level 1
mcbsp
FYI:
I have learned to install JP1 and stunt it on the
DSK6711 to gain McBSP0 signal access from
the peripheral connector.
New question:
Anyone have experience developing daughter cards for DSKs??
If so, is there any info you can share with newbie developers?
Sparrow
Prosty
Newbie level 1
mcbsp1 problems
Hi, I have developed a card with a PCM3010 to do digital audio effects. I have used the serial port, it's not so simple. But if you have problems ask me, I see if I can help you.
