[SOLVED] ds1977-f5# copy data
brunofunchas
Full Member level 3
Portugal
Is it possible to copy the data from one EEPROM to another?
If yes, how can I do it?
Thanks,
Bruno
Do you know how to read an EEPROM?
Do you know how to write an EEPROM?
If you can both .. you're done.
If there is a NO, then tell us why?
All you need to do is written in the datasheet. What item of the datasheet did you not understand?
I don't know how to read data and also how to check if it read protected. Please indicate me the hardware that I can use or a datasheet where I can read from.
This EEPROM is used as a count down counter in a machine.
Thanks,
Bruno
