DS18B20 question about delays
bednyk
Hi!
I am just developing a board with digital termomter. I would like to ask how to measure times required for 1-Wire transmission. Should I use timer and interrupt? Using this way should I change timer counting time every interrupt? or is there any better algorithm to write such program.
All voices are welcome...brainstorm needed ;)
BR,
Mike
The answer depends on other uses of your resources. As far as the DS18B20 is concerned, where the delay comes form is irrelevant.
If your processor is fast and nothing else in your software is going to hold things up, use software delay loops. If the timing is critical because other things might slow the loop down, use interrupts instead.
The DS series are actually quite tolerant of timing, the 'window' for 1's and 0's is quite wide in terms of typical microprocessor instruction cycles.
Brian.
