/* Multipoint thermometer with LCD display
using the Maxim DS18B20
1 Wire bus temperature sensors
CodeVisionAVR C Compiler
(C) 2000-2005 HP InfoTech S.R.L.
[url]www.hpinfotech.ro[/url]
Chip: ATmega8515
Memory Model: SMALL
Data Stack Size: 128 bytes
THE ATmega8515 CLOCK FREQUENCY MUST BE 3.6864 MHz
The DS18B20 sensors are connected to
bit 6 of PORTA of the ATmega8515 as follows:
[DS18B20] [STK500 PORTA HEADER]
1 GND - 9 GND
2 DQ - 7 PA6
3 VDD - 10 +5V
All the temperature sensors must be connected
in parallel
AN 4.7k PULLUP RESISTOR MUST BE CONNECTED
BETWEEN DQ (PA6) AND +5V !
#asm
.equ __w1_port=0x1b
.equ __w1_bit=6
#endasm
/* Use an 2x16 alphanumeric LCD connected
to PORTC as follows:
[LCD] [STK500 PORTC HEADER]
1 GND- 9 GND
2 +5V- 10 VCC
3 VLC- LCD contrast control voltage 0..1V
4 RS - 1 PC0
5 RD - 2 PC1
6 EN - 3 PC2
11 D4 - 5 PC4
12 D5 - 6 PC5
13 D6 - 7 PC6
14 D7 - 8 PC7
#asm
.equ __lcd_port=0x15
#endasm
#include <lcd.h> // LCD driver routines
#include <ds18b20.h>
#include <delay.h>
#include <stdio.h>
char lcd_buffer[33];
/* maximum number of DS18B20 connected to the 1 Wire bus */
#define MAX_DEVICES 8
/* DS18B20 devices ROM code storage area */
unsigned char rom_code[MAX_DEVICES][9];
main()
unsigned char i,j,devices;
lcd_init(16);
lcd_putsf("CodeVisionAVR\n1 Wire Bus Demo");
delay_ms(2000);
lcd_clear();
/* detect how many DS18B20 devices
are connected to the 1 Wire bus */
devices=w1_search(0xf0,rom_code);
sprintf(lcd_buffer,"%u DS18B20\nDevice detected",devices);
lcd_puts(lcd_buffer);
delay_ms(2000);
/* display the ROM codes for each device */
if (devices)
for (i=0;i<devices;i++)
sprintf(lcd_buffer,"Device #%u ROM\nCode is:",i+1);
lcd_clear();
delay_ms(2000);
lcd_clear();
for (j=0;j<8;j++)
sprintf(lcd_buffer,"%02X ",rom_code[i][j]);
if (j==3) lcd_gotoxy(0,1);
delay_ms(5000);
else
while (1); /* stop here if no devices were found */
/* configure each DS18B20 device for 12 bit temperature
measurement resolution */
for (i=0;i<devices;)
if (!ds18b20_init(&rom_code[i++][0],20,30,DS18B20_12BIT_RES))
sprintf(lcd_buffer,"Init error for\ndevice #%u",i);
lcd_clear();
while (1); /* stop here if init error */
/* measure and display the temperature(s) */
while (1)
j=1;
sprintf(lcd_buffer,"t%u=%+.3f\xdfC",j++,ds18b20_temperature(&rom_code[i][0]));
lcd_clear();
delay_ms(500);
