DS1337 with XMEGA problem (TWI)
Sharagim
Full Member level 1
I am trying to use ds1337 with Xmega, but I can't get proper result.
Sometimes the code stuck in loop(Below) at startup (even flashing or reboot).
When it pass the the Stratup sequence it is working ok. I want to know if this is normal on Startup or not?
while (twiMaster.status != TWIM_STATUS_READY) {}
  • DS1337.txt
Maybe you need to add some delay (about 100ms) before accessing the I2C bus (after the init)...
also this kind of problem arise when you don't check properly the TWI status value, maybe a too high pull up value? (I usually don't have problems with a 4.7k or 10k pull up, but it's said that you can lower it more) maybe noise interference? (I had a circuit that when you touched the SCK line with a finger it halted in the same kind of loop)
finally, the best way is to implement a counter or some way to exit the loop for example:
long int count;
//in code
count=0; //always clear the counter before the while
  if(++count>100000) break;// this 100000 should be aprox 10ms which I think is enough time for any twi operation
if(count>100000){/*do something here in case of twi failure... check your doc if you need to reset the module in some sort of way*/}
//else, continue with the original program
Thank you very much for your reply.
No help with Delay.
I think your idea about counter will help. I tried different values for pull-up but nothing happened.
BR,
