gopi the king
Junior Member level 2
- Joined
- Nov 20, 2012
- Messages
- 22
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Coimbatore, Tamil Nadu, India
- Activity points
- 1,421
Hai,
now i am doing program for interfacing DS1307 with lpc2148 using I2C communication protocol. i got this code from net but it is not working properly. the output is like 00:00:00 then in next line 00-00-00. i think that program have some minute error please clear that.
or else if u have some other program kindly send me, it will be very useful for me
below program is the one i got in internet.
[syntax=c]/*
PORT 0.3-SDA LINE
PORT 0.2-SCL LINE
LCD DISPLAY
PORT 1.16-1.23 - DATA LINES
PORT 0.4- RS PIN
PORT 0.5- RW PIN
PORT 0.6- EN PIN
#include<lpc214x.h>
unsigned int val,n;
unsigned char a[8]={0};
void lcdready(void)
IODIR1=0X007F0000; /* MAKE D7 AS A INPUT PIN & D0-D6 AS OUTPUT PINS */
IOSET1=0x00800000; /*MAKE D7=1*/
IOCLR0=0x00000010; /* RS(P0.4)=0 */
IOSET0=0x00000020; /* R/W(P0.5)=1 */
while((IOPIN1&0x00800000)== 0x00800000) /* IF D7 IS HIGH STAY HERE */
IOCLR0=0x00000040; /* EN(P0.6)=0 */
IOSET0=0x00000040; /* EN(P0.6)=1 */
void lcdcommand(void)
lcdready();
IODIR1=0X00FF0000; /* P1.16..23 defined as Outputs */
IOPIN1 = n;
IOCLR0=0x00000020; /* R/W(P0.5)=0 */
IOCLR0=0x00000040; /* EN(P0.30)=0 */
void lcddatawrt(void)
lcdready();
IOPIN1 = n;
IOSET0=0x00000010; /* RS(P0.4)=1 */
void lcd_initialization(void)
//PINSEL1=0x00000000; /*MAKE 0.28,0.29,0.30 AS I/O*/
//PINSEL2=0x00000000; /*MAKE 1.16...1.23 AS I/O*/
n=0x00380000;
lcdcommand();
n=0x000c0000;
lcdcommand();
n=0x00060000;
lcdcommand();
n=0x00010000;
lcdcommand();
void year()
unsigned char s;
n=0x00c60000;
lcdcommand();
s=a[6]>>4 ;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s=a[6] & 0x0f;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s=' ';
val=s;
n=val<<16;
lcddatawrt();
void month()
unsigned char s;
n=0x00c30000;
lcdcommand();
s=a[5]>>4 ;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s=a[5] & 0x0f;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s='-';
val=s;
n=val<<16;
lcddatawrt();
void date()
unsigned char s;
n=0x00c00000;
lcdcommand();
s=a[4]>>4 ;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s=a[4] & 0x0f;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s='-';
val=s;
n=val<<16;
lcddatawrt();
void hour()
unsigned char s;
n=0x00800000;
lcdcommand();
s=a[2]>>4 ;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s=a[2] & 0x0f;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s=':';
val=s;
n=val<<16;
lcddatawrt();
void min()
unsigned char s;
n=0x00830000;
lcdcommand();
s=a[1]>>4 ;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s=a[1] & 0x0f;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s=':';
val=s;
n=val<<16;
lcddatawrt();
void sec()
unsigned char s;
n=0x00860000;
lcdcommand();
s=a[0]>>4 ;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s=a[0] & 0x0f;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
void day()
unsigned char s;
n=0x00890000;
lcdcommand();
/*s=a[]>>4 ;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
s=a[3] & 0x0f;
s=s+0x30;
val=s;
n=val<<16;
lcddatawrt();
int main()
unsigned char i,j=0;
PINSEL0= 0X00000050;
PINSEL1= 0x00000000; /*MAKE 0.28,0.29,0.30 AS I/O*/
IODIR1 = 0x00FF0000; /* P1.16..23 defined as Outputs */
IODIR0 = 0x000000f0;
lcd_initialization(); //INITIALIZATION OF LCD
I2C0SCLL =0X4B; //TO SET BUAD RATE OF I2C
I2C0SCLH=0X4B; //TO SET BUAD RATE OF I2C
I2C0CONSET=0X40; //TO ENABLE I2C
while(1)
I2C0CONSET=0X20; // TO SEND START CONDITION
while(I2C0STAT!=0X08 || I2C0CONSET!=0X68);
I2C0CONCLR=0X20;
I2C0DAT=0XD0; //SLAVE ADDRESS + WR
I2C0CONSET=0X08;
while(I2C0STAT!=0X18 &&I2C0CONSET!=0X48);
if(I2STAT!=0X18) //IF NO ACK FROM SLAVE
I2C0DAT=0X00;
I2C0CONCLR =0X08;
while(I2STAT!=0X28 && I2C0CONSET!=0X48);
I2C0CONCLR =0X08;
I2C0CONSET=0X10;
//I2C0CONCLR =0X08;
while((I2C0CONSET&0x08)!=0X08);
//I2C0CONCLR =0X20;
n=0x00010000;
lcdcommand();
n=0x00300000;
lcddatawrt();
while(1);
else;
I2C0DAT=0X00; // DATA WRITE TO SALVE
I2C0CONCLR=0X08;
while(I2C0STAT!=0X28 &&I2C0CONSET!=0X48);
if(j==0)
I2C0CONCLR =0X08;
I2C0DAT=0X15; // DATA WRITE TO SALVE
I2C0CONCLR =0X08;
I2C0DAT=0X18; // DATA WRITE TO SALVE
I2C0CONCLR =0X08;
I2C0CONCLR =0X08;
I2C0DAT=0X07; // DATA WRITE TO SALVE
I2C0CONCLR =0X08;
I2C0DAT=0X11; // DATA WRITE TO SALVE
I2C0CONCLR =0X08;
I2C0DAT=0X12; // DATA WRITE TO SALVE
I2C0CONCLR =0X08;
I2C0DAT=0X10; // DATA WRITE TO SALVE
I2C0CONCLR =0X08;
j++;
else;
I2C0CONSET=0X20; //REPEATED START
I2C0CONCLR =0X08;
while(I2C0STAT!=0X10 || I2C0CONSET!=0X68);
I2C0CONCLR =0X20;
I2C0DAT=0XD1; //SLAVE ADDRESS + READ
I2C0CONCLR =0X08;
while(I2C0STAT!=0X40 && I2C0CONSET!=0X48);
if(I2STAT!=0X40) //IF NOT ACK FROM SLAVE
I2C0DAT=0X00;
I2C0CONCLR =0X08;
I2C0CONCLR =0X08;
I2C0CONSET=0X10;
//I2C0CONCLR =0X08;
//I2C0CONCLR =0X20;
//while((I2C0CONSET&0x08)!=0X08);
n=0x00010000;
lcdcommand();
n=0x00320000;
lcddatawrt();
while(1);
for(i=0;i<6;i++) //REPEATE FOR 6 TIMES
I2C0CONCLR =0X08; //CLEAR SI
I2C0CONSET=0X04; //TO SEND ACK FROM MASTER TO SLAVE
a[i]=I2C0DAT; //TAKING THE DATA RECEIVED FROM SLAVE
I2C0CONCLR =0X0C; //CLEAR SI AND AA BIT
I2C0CONSET=0X10; //TO SEND STOP SEQUENCE
I2C0CONCLR =0X08;
while((I2C0CONSET&0x10)==0X10);
I2C0CONCLR =0X08;
hour(); //TO DISPLAY HOUR
min(); //TO DISPLAY MINS
sec(); //TO DISPLAY SECONDS
date(); //TO DISPLAY DATE
month(); //TO DISPLAY MONTH
year(); //TO DISPLAY YEAR
//day();
}[/syntax]
