DS1302 RTC interfacing with 8051
ebenni
Turkey
ds1302 rtc
hi,
C code.
rtc ds1302
A very important point for the design accuracy is to use a 'Matched Capacitance Crystal" of 6pF, i've tried to use a non-matched capacitance crystal (at the same 32768 Hz) and had a time latencey of about 2-3 minutes a day.
Matched crystals can easily be found, e.g., wxw.dontronics.com
ds1302 c code
Yeah, it pays to read the datasheet! I spent two
days trying to figure out why this RTC wasn't
keeping proper time. Silly me - I was using a
12.5pf crystal.
ds1302 programing
DS1302 AND PBP RTC CODE
'***** MBYKA **********
' DS1302 RTC use
Include "MODEDEFS.BAS"
Define LCD_DREG PORTB
Define LCD_DBIT 4
Define LCD_RSREG PORTB
Define LCD_RSBIT 0
Define LCD_EREG PORTB
Define LCD_EBIT 1
'pins
RST var PORTA.0
IO var PORTA.1
SCLK var PORTA.2
'variables
rtcyear var byte
rtcday var byte
rtcmonth var byte
rtcdate var byte
rtchr var byte
rtcmin var byte
rtcsec var byte
rtccontrol var byte
Main:
Low RST ' Reset RTC
Low SCLK
' saat Set 13:42:00 04/13/02
rtcyear = $02
rtcday = $06
rtcmonth = $04
rtcdate = $13
rtchr = $13
rtcmin = $42
rtcsec = $00
Gosub SetTime
Goto Main_Loop
Main_Loop:
Gosub gettime ' saati oku
Lcdout $fe, 1 '1.satır
lcdout hex2 rtcmonth, "/", hex2 rtcdate, "/" , hex2 rtcyear
lcdout $fe,$c0
lcdout hex2 rtchr, ":", hex2 rtcmin, ":", hex2 rtcsec
Pause 300 ' 0.3 saniye bekle
Goto Main_Loop
SetTime:
RST = 1 ' Ready for transfer
' Enable write
Shiftout IO, SCLK, LSBFIRST, [$8e, 0]
RST = 0 ' Reset RTC
' Write all 8 RTC registers in burst mode
Shiftout IO, SCLK, LSBFIRST, [$be, rtcsec, rtcmin, rtchr, rtcdate, rtcmonth, rtcday, rtcyear, 0]
RST = 0 ' Reset RTC
Return
GetTime: ' Subroutine to read time from RTC
Shiftout IO, SCLK, LSBFIRST, [$bf] ' Read all 8 RTC registers in burst mode
Shiftin IO, SCLK, LSBPRE, [rtcsec, rtcmin, rtchr, rtcdate, rtcmonth, rtcday, rtcyear, rtccontrol]
RST = 0 ' Reset RTC
Return
End
c code for ds1302
' DS1302 RTC use
Define LCD_DBIT 4
Define LCD_RSBIT 0
Define LCD_EBIT 1
'pins
RST var PORTA.0
IO var PORTA.1
SCLK var PORTA.2
'variables
rtcyear var byte
rtcday var byte
rtcmonth var byte
rtcdate var byte
rtchr var byte
rtcmin var byte
rtcsec var byte
rtccontrol var byte
Main:
Low RST ' Reset RTC
Low SCLK
rtcyear = $02
rtcday = $06
rtcmonth = $04
rtcdate = $13
rtchr = $13
rtcmin = $42
rtcsec = $00
Gosub SetTime
Goto Main_Loop
Main_Loop:
lcdout $fe,$c0
Goto Main_Loop
SetTime:
' Enable write
RST = 0 ' Reset RTC
RST = 0 ' Reset RTC
Return
RST = 0 ' Reset RTC
Return
End
good and great nice work mybka i used the timming crystal which is best i think come from old digital rest watch they work good and no matching problem accuracy is fine, in a month 1 second error in time
regards
Fragrance
rtc programming
programming pc rtc
hi there,
I tried compiling the code posted by ebenni on MPLAB IDE (MCC18) with PIC 18F452
I got the following error
Error [1027] unable to locate 'intrins.h'
Error [1027] unable to locate 'reg51.h'
Error [1027] unable to locate 'geral.h'
I was wondering if anyone can attach these header files or tell me where I can find it.
thanks in advance,
