Dungnv
Newbie level 3
- Joined
- Sep 21, 2011
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,300
Base on described theory about TMM for photonic crystal J.B. Pendry, J. Mod. Opt.41, 209 (1994), Prof. Pendry also uploaded a program using Fortran language [attachment] to calculate transmission/reflection coefficients of complex structure (2D dimensions).
The problem is, i want to perform this code to calculate T&R spectra View attachment adag_v1_0.gzfrom cut-wire pair structure.
This is my subroutine to define CWP structure, but it provide wrong results when i compare with CST program:
and the second question is, when i try to use Drude's model for epsilon of metal part, then T and R become infinitive.
Anyone know this method, help me plz.
Code Fortran - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 subroutine DEFSTR(EPSPOT,IXMAX,IYMAX,IZMAX,EPS,EPSREF,EPSSUB) c integer IXMAX,IYMAX,IZMAX,IX,IY,IZ complex*16 EPSPOT(IXMAX,IYMAX,IZMAX),EPS,EPSREF,EPSSUB do 5 IX = 1,IXMAX do 5 IY = 1,IYMAX do 5 IZ = 1,IZMAX if ((IZ .EQ. 2) .OR. (IZ .EQ. 4)) then if ((IY .GE. 3).AND.(IY .LE. 16) .AND. & (IX .GE. 4) .AND. (IX .LE. 6)) then EPSPOT(IX,IY,IZ) = EPS else EPSPOT(IX,IY,IZ) = EPSREF end if elseif ((IZ .EQ. 3)) then EPSPOT(IX,IY,IZ) = EPSSUB else EPSPOT(IX,IY,IZ) = EPSREF end if 5 continue return end
