driving stepper motor
khushi_123
Member level 1
i have made this stepper motor driver..the diodes which i have used are fast recovery diodes(2A)..but this is not working..l298 becomes hot..i have 6-wired motor its common windings are not connected to anything..remaining 4 wires are connected to the circuit..applied volttage is 12v..is it enuff???..HELP..
FvM
Super Moderator
Staff member
Bochum, Germany
You should have at least an idea about the motor data. Operating an unipolar motor with a bipolar driver should basically work. Even with inappropriate voltage/current settings, you should be able to perform single steps.
khushi_123
Member level 1
here is the schematic..plz help me with this..
FvM
Super Moderator
Staff member
Bochum, Germany
You have already shown it, it's almost similar to the datasheet reference circuit. I asked about motor data.
khushi_123
Member level 1
model number is PK245-01BA, 2 phase 1.8, DC 1.2A, 3.3 ohm..
kindly guide me with this..
FvM
Super Moderator
Staff member
Bochum, Germany
I would expect that the motor can work with a phase current programmed to 0.8 A maximum. If it's not moving at all, there's probably a problem in your circuit that can't be seen in the schematic.
When performing single steps manually, you should be able to see winding voltages according to the usual step motor pulse pattern.
