Boky
Hello everyone,
I have one question.
When I simulate circuit below it shows error if I start simulation while signal voltage is set to be lower then reference voltage (mosfet should be OFF).
But if I start simulation while signal voltage is set to be greater then reference voltage everything works fine (mosfet ON), I can then during simulation decrease signal voltage to be lower then reference voltage and mosfet will turn OFF and then if I again increase signal voltage above reference voltage mosfet again turns ON and there is no error.
So error occurs only in one case and I don't know whether this part of circuit will work fine in real life? Is this some error in Proteus or I am maybe doing something wrong?
Best regards
Best regards
