Driving LED at 60 MHz
iamalearner
Newbie level 5
Hi
I need to design an LED driver circuit at a frequency of 60 MHz. The LED output light modulated at 60 MHz will be used to excite a sensor and then the light reflected from the sensor will be converted into current for further processing.
Any ideas for driving LED at 60 MHz? I want to keep the current consumption low too.
It's easy to drive the LED with a transistor current source or simply through a resistor. But you should consider that many
LEDs have cut off frequencies around 10 or 20 MHz, so the modulation depth at 60 MHz will be poor.
Hi iamalearner,
What kind of wavelength do you need please?
My be a(NIR) VCSEL will be better for your goal?
K.
karesz said:
Hi iamalearner,
K.
Hi
The LED used is yallow/amber (590 nm) wavelength. What is VCSEL?
- jeet
Hi -jeet,
VCSEL= Vertical Cavity Surface Emitting Laser.
Usually needs relative smaller Current & the most positive data: Profile of the light-ray is equivalent with the "Top Electrode" from Chip.
This is usually a circle, the convergence is practically optimal too(has very strong parallel light & needs no collimation...)
Please check it (for example):
http://www.opticsinfobase.org/abstract.cfm?uri=ol-32-19-2831
http://en.wikipedia.org/wiki/Vertical-cavity_surface-emitting_laser
In Europe are the best (research)sources:
CSEM, OSRAM, Uni Ulm, ETH Zürich, Uni Stuttgart; Uni Chemnitz...
What is your application please?
If you tell "I have LED to pulse-drive with 60MHz"; it means for me=fiber driving or spectrometry & comes the question:
You must have really yellow light , or can be infrared to?...
You can by (today) VCSEL from ca. 700 nm up to ca. 4-5um.
K.
Added after 47 minutes:
You can check that too:
www.analog.com/static/imported-files/application_notes/AN_634.pdf
This has relative good/perfect controlling/stabilization, but my be you dont need to build so precise circuits?
Than you can take a simple High-Speed AC-MOS gate!:))
They has up to +/-24 mA driving capability and if you need more current, you can coppel it more time parallel and its packages are smallest SMD...
www.fairchildsemi.com/ds/NC/NC7WZ17.pdf
I soluted a project ca. 9 years ago with some similar type from Toshiba, & TI for 40MHz Clks, there worked over 8 years in very special field....
If you have power (or current) problems is important to know, Laser-diodes need usually up to 100-200 mAmps_ in opposite VCSEL at 5-20mAmps & LEDs at 50+/_20mAmps- or so...
K.
