Driving LED at 60 MHz
iamalearner
Newbie level 5
Hi
I need to design an LED driver circuit at a frequency of 60 MHz. The LED output light modulated at 60 MHz will be used to excite a sensor and then the light reflected from the sensor will be converted into current for further processing.
Any ideas for driving LED at 60 MHz? I want to keep the current consumption low too.
Thanks
FvM
Super Moderator
Staff member
Bochum, Germany
It's easy to drive the LED with a transistor current source or simply through a resistor. But you should consider that many
LEDs have cut off frequencies around 10 or 20 MHz, so the modulation depth at 60 MHz will be poor.
karesz
Advanced Member level 5
EU
Hi iamalearner,
What kind of wavelength do you need please?
My be a(NIR) VCSEL will be better for your goal?
K.
iamalearner
Newbie level 5
karesz said:
Hi iamalearner,
K.
Hi
The LED used is yallow/amber (590 nm) wavelength. What is VCSEL?
- jeet
karesz
EU
Hi -jeet,
VCSEL= Vertical Cavity Surface Emitting Laser.
Usually needs relative smaller Current & the most positive data: Profile of the light-ray is equivalent with the "Top Electrode" from Chip.
This is usually a circle, the convergence is practically optimal too(has very strong parallel light & needs no collimation...)
Please check it (for example):
https://www.opticsinfobase.org/abstract.cfm?uri=ol-32-19-2831
https://en.wikipedia.org/wiki/Vertical-cavity_surface-emitting_laser
https://www.wsi.tum.de/Research/Ama.../SurfaceEmittingLasers/tabid/110/Default.aspx
In Europe are the best (research)sources:
CSEM, OSRAM, Uni Ulm, ETH Zürich, Uni Stuttgart; Uni Chemnitz...
What is your application please?
If you tell "I have LED to pulse-drive with 60MHz"; it means for me=fiber driving or spectrometry & comes the question:
You must have really yellow light , or can be infrared to?...
You can by (today) VCSEL from ca. 700 nm up to ca. 4-5um.
K.
Added after 47 minutes:
You can check that too:
www.analog.com/static/imported-files/application_notes/AN_634.pdf
This has relative good/perfect controlling/stabilization, but my be you dont need to build so precise circuits?
Than you can take a simple High-Speed AC-MOS gate!:))
They has up to +/-24 mA driving capability and if you need more current, you can coppel it more time parallel and its packages are smallest SMD...
www.fairchildsemi.com/ds/NC/NC7WZ17.pdf
I soluted a project ca. 9 years ago with some similar type from Toshiba, & TI for 40MHz Clks, there worked over 8 years in very special field....
If you have power (or current) problems is important to know, Laser-diodes need usually up to 100-200 mAmps_ in opposite VCSEL at 5-20mAmps & LEDs at 50+/_20mAmps- or so...
K.
