I am using a mosfet driver, IR2106 to drive my n-mosfet on both highside and lowside. Is it as refer to the datasheet of IR2106 circuit, both my mosfet will work? What else can it be wrong?
This driver can drive 2 N-mosfets, one high side and one low side.
Your schematic is too small and i also don't understand what is the actual problem you have with the circuit.
what i can see here is voltage source and some capacitor which does'nt mach with HI and Lo side driver,kindly draw the real diagram for us to understand it more.
