DRC using calibre in umc90nm
sumanmicro
BITS PILANI,India
While running DRC in virtuoso for umc90nm ,it gives an error as
line 320 of (DRC selected file),unable to open or access file type
and that file is ./90nm_layers.cal
I dont know why that error occurs
the restricted foundry document or the staff from UMC will give you a hint.
basically, calibre is looking for that file, but that file cannot be accessed...
I also got similar error for UMC 180nm. I simply copied contents of each file it has load command in the main DRC file and it worked.
Hope this helps
Zopeon
actually better use assura
I could not rectify that error ,but when i used assura based DRC ,there wasn't any error .
In assura it works fine
bcoz .cal file is required only for calibre verification.. not assura...;)
HI,
The Calibre tools searches the file "90nm_layers.cal" in your "calibre" working directory , but this file may not exist in this directory . Thus the calibre tool exits with Error.
one solution is copy the file "90nm_layers.cal" from umc90nm tool kit path (from where you copied calibre.drc file) to Calibre working directory and Run calibre again.
Other Solution is edit the line "./90nm_layer.cal" in calibre.drc rule file , to specify the correct existing path of file , and Run calibre again.
Cheers...
