draw circular spiral inductor in HFSS
myem
Full Member level 2
Full Member level 2
How to draw circular spiral inductor in HFSS ?
I saw only rectangular spiral build with script. You can seen it in examples/
I would use the equation based plot feature in HFSS to generate the particular spiral I had in mind if one of their wizards was not sufficient.
it is very simple, just use the polygon model and the a just it.
if you want a spiral type circular inductor, the it's better to use equation base method.
Hi Guys,
I am designing a circular spiral inductor. Can someone help me out how do you feed the circular spiral induc?
Kirthiinu...
type spiral HFSS help... it may help you!!!
