Drain-source resistance (R_{DS(ON)}) of power MOSFET for Boost/Buck converter
Wanoz
Junior Member level 1
How to calculate drain-source resistance of power MOSFETs for boost converter?
timof
Advanced Member level 2
San Jose, CA, USA
Do you want to take into account parasitic resistance of source / drain metallization? (this can contribute as much as 50% or more to the total Rdson, and can also create problems like current density / electromigration, uneven current distribution over device area or pads/balls, etc.).
If yes - you need to use a specialized software tool that is designed to handle these layouts properly (two-dimensional meshing of complex metal shapes, fracturing of gates along gate width, treating the device in truly distributed manner, etc.).
If not - you can can just use SPICE simulation for your power transistor, but you will get only device resistance part, and will not see any of the effects / problems mentioned above.
rangermad
Full Member level 3
Mask Designer needs to know the target RSDon so they can limit the parasitic resistances. Ideally <10% of the RDSon.
