Dracula LVS says "Segmentation Fault"
bhat
I am facing a problem with DRACULA LVS. When I run jxrun.com, it dumps the core ( Segmentation fault). Can anybody help me to solve this problem.
Thanks and Regards
Ramesh
snaityma
Junior Member level 3
Did you check PRINT.OUT file after executed LOGLVS utility ?
Maybe, there are some error messages there.
OR, any error report when PDRACULA was exectued?
bhat
Thanks for the reply. PRINT.OUT does not show any significant information but it shows ... Processing the input file ... Thats all
No error report when PDRACULA was exectued.
Regards
analogtmp
Newbie level 6
You can try to remove the file named core in the UNIX system,try?
snaityma
In the end of PRINT.OUT file, are there abnormal info. at summary report, like box number, nmos/pmos type number., etc? OR
Did you wirte Dracula LVS command file by youself?
Do you specify text file in dracula lvs command file?
Maybe you need to check LVS command file description.!
cyrabbit
Member level 2
Thanks and Regards
Ramesh
Which version of your DRACULA?update to lastest version.
xinsu
Member level 3
this maybe operating system error,you can exit dracula and try again.
Hughes
Advanced Member level 3
Thanks and Regards
Ramesh
How many transistors are there in your design? Do you have check your disk quota or physical disk capacity?
lctlcm
Reboot the workstation.
(Flush out the old accumulate data that chock up your system)
