Dracula generates .DAT file, is it normal?
snaityma
Junior Member level 3
dracula working directory
When I use Dracula to check DRC error,
Dracula generated "-.DAT" file in my working directory.
Does anyone know that what command in command file create it?
Is it normal?????? :?:
Hughes
Advanced Member level 3
dracula smart inquery
It is normal enough. After you run jxrun.com, a lot of '.DAT' files are generated. So you should make a new directory as Dracula working directory. When you don't need these files, you can just remove all the files in this directory.
sulifen
Member level 2
ROT
how to change default directory in dracula
Before running Dracula, you should have to run PDRACULA first to "compile" your command file.
When PDRACULA done, it will generates the "j***.***" files, and the "jxrun.com" is the really what Dracula to run file. You can use vi to view this file, there are many stages in it, every stage is a individual execution command. They generates the "*.DAT" files. And they can be simply delete by "rm" command when your Dracula done.
And in your command file, in the *DESCRIPTION block, a command called KEEPDATA= can accept these options:
YES: keep all DAT files when Dracula done.
SMART: only keep useful DAT files when Dracula done.
INQUERY: generates extra DAT file for Dracula Interactive.
DRACULAINTERACTIVE: same as INQUERY
NO: deletes all the binary-generated files at the very end of the Dracula.
sulifen
Member level 2
ROT
change working directory in dracula
If you have installed the openbook that came from C@dence, you can execute it and find out more detail information about Dracula usage.
snaityma
question on dracula
I know Dracula generate many *.DAT files in working directory.
But I find that it generate a special file, that file name is just -.DAT
In my command file, I do not output any file using the name "-".
I think it is very stranger!!! :?: How come?
sulifen
Member level 2
ROT
question about dracula
What version are you using?
I'm using V4.8 and I never saw a -.DAT file in running directory.
snaityma
dracula drc inquery smart
The PDRACULA version I use is V4.8
That is very strange!
I check my command file many times.
PDRACULA does not report any errors/warnings message.
strange :?: :?: :(
AppleGuo
Newbie level 1
China
dracula drc smart
HI,guys,
Do you know how to change the working directory of Dracula.
I tried WORK-DIR = ...
But It didn't work.
thanks.
