download zeland program manager
hariharanwebmail
issue with eval.zip of ie3d software
My Zeland license manager crashes every 15 min is there any way to avoid it ???????????????????????????
jian
Advanced Member level 3
Hi:
It is due to instable internet connection. It will not happen in LAN or corporate WAN. The good news is that we are going to come out with a stand-alone evaluation license without using internet connection in IE3D V12. It should happen in about 2 weeks. We are doing the final test right now. I think it will be there by the end of the month or early next month. I am Jian from Zeland.
Best regards,
jian
Re: IE3d
Yes. The new one does not require continuous internet connection. It will not be affected by the stability of internet. Regards.
hariharanwebmail
Re: IE3d
ERROR
I downloaded the new version from zeland.com (eval.zip 151 MB)
I installed the entire software...................
The zeland program manager is not working/not found since it invokes the searching window with browse and cancel..........
To my surprise i didnt find zeland.exe which basically is the zeland program manager anywhere ...........
please help me out asap :cry:
jian
Re: IE3d
Hi, hariharanwebmail:
I am not sure why you can't find zeland.exe (or ZPM) from the installation in eval.zip. Since we introduced the Zeland Evaluation Kit V12 two weeks ago, many evaluators have downloaded it and we have not heard any similar report. We did check with some evaluators and they told us the process was very smooth. I am not sure why it does not work on your computer. I assume you did not download the products.zip which is supposed to be for customers. Each customer has a unique ZPM. The ZPM will not be inside the products.zip, which is for all customers. You can contact me at jian@zeland.com on it. Thanks!
Best regards,
