Doubts on Allegro PCB editor
Deepikaaa
Member level 2
Chennai, Bangalore
Hi frnds....
I am having some doubts on allegro pcb editor... I thank u so much for you reply..
1. I want to know that what are the necessary values to be set in the constraint manager??
2. how to make holes in the four corners of the board??
3. How to make holes in the base of one of the IC pad-stack to be used as a soldering hole??
Thank u so much...
Deepikaa
assume you are new to PCB design
1 . constraint manager - depends on your PCB reqiurement. It may be physical clearance to SI constarints like lenghth matching, cross talk,impedance etc
2. Mounting holes -- location and drill size - depends on enclosure/casing/cabinet whre PCB is spoosed to rest
can be placed as symbols in allegro
3. means Thru hole component?? Use padstack designer
yea... s sir.. i am a beginner to this allegro.. thank u so much for your response and also for spending your time for me.
can you plz say me that what are the parameters should be set in the physical, electrical and spacing constraints??
Deepikaa
for normal designs setting spacing parameters,select via from physical etc will do
thank u sir...
can u plz say me that where is mounting hole option???
and also i want to put some holes in the one of the padstack of IC, which is to be used as an soldering hole.. my hardware engg told me that the ic is having ground pin on the base of the IC.
Deeps....
for mounting hole you may need to crate new DRA file with desired drill size. Some footprints are available at
<installed locations>:\Cadence\SPB_15.7\share\pcb\pcb_lib\symbols\
regarding the IC I am little bit confused are you looking for a thru hole IC( DIP IC) .
Normally packages like QFN comes with a pad .In picture Pin 25 . But here we need a SMD pad for soldering and manually such soldering is difficult and need to go for machine soldering.
sir..
that is SMD IC, which s having 25th pin on the bottom base.. i need to put a hole for two purpose. the major reason is to hold the IC firmly....
what kind of hole i can use..via?? how to assign?? plz guide me sir..
Deepsss..
Hi Deepsss,
I think you have multiple options here.
1 . Place a Via with required size
2. Place a symbol ( just like you added mounting hole)
3. In the footprint itself define a thru hole pad ( ie for the last picture the 25th pin will be a thru hole pad , you can place it as a 'mechanical pin' if you dont need any connection there. or defie it as a 'connect pin' and in your schematic symbol there will be 25 pins.
And I believe the best option is the 3rd one.
