doubts is calculating 3 phase motor current
raman00084
Full Member level 6
Full Member level 6
assume that i am having a 3 phase motor running in 440v ac supply. If i connect a clamp meter on each phase of the motor i am getting 1.2a current, how to calculate the current for 3 phase motor should i must add all the 3 that is 3.6a ?
regards
kalyan
No. You do not need to calculate. You should say the current is 1.2A per phase or simply 1.2A.
