abbagownisaiprasad
Newbie level 1
- Joined
- Apr 26, 2013
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,290
Hello friends,
i want the verilog code for square root of 32 bit number. i tried a lot with many programs but those are working for small values of integer numbers only. i have tried to use ip core too but the delay has been increased when i use ip core. i'm using xilinx 10.1 with virtex-4 as my target device. i'm not able to find a solution. please help me regarding this issue. one more point i forgot to say that i'm not getting the simulated output when i use ip core in xilinx 10.1, i don't know what is the problem is....
But when i'm using ip core in xilinx 14.2 i'm getting the correct simulated output. what to do with this, can i use 14.2 ip core in 10.1 version if no please say the solution to solve this problem.
Thank you.
Thank you.
