hacksgen
Member level 3
I have a question on sigma delta adc for receivers. In one of the papers I have read the following.
Imagine the conversion of a signal centered at 1 MHz with 10-kHz bandwidth. With a 10-MHz sampling rate, a traditional converter would provide five times oversampling;
a bandpass ∑Δ converter would achieve 500 times oversampling.
Can anyone explain the meaning of the sentence.
If a ∑Δ converter is converting the signal with center frequency at 1MHz(which I am assuming in modulated signal downconverted from RF to 1MHz) than would not the oversampling still be the same for ∑Δ as it will only be able to sample the 1MHz signal at 10MHz sampling rate.
