edrin_88
Junior Member level 1
This is the code for cpld xc9572 which has the system clock 32 khz.but how is it reduced to 25 hz?
entity cntr7seg is
port(
clk : in std_logic;
reset : in std_logic;
disp0 : out std_logic;
s0 : in std_logic;
display : out std_logic_vector(6 downto 0)
end cntr7seg;
architecture cntr7seg_arch of cntr7seg is
--local signal declaration
signal count : std_logic_vector(14 downto 0);
signal bcd_out1 : std_logic_vector(3 downto 0);
signal clk_4hz : std_logic;
begin
--This process divides the system clock of 32KHz, to scale it
--down to 25 Hz.?? but how?
process(clk,reset)
begin
if reset='1'then
count <=(others=>'0');
elsif clk='1' and clk'event then
count <= count + '1';
end if;
end process;
clk_4hz <= count(14);
entity cntr7seg is
port(
clk : in std_logic;
s0 : in std_logic;
end cntr7seg;
begin
process(clk,reset)
begin
if reset='1'then
end if;
end process;
