Doubt about port protection from mistaken connections
blapcb
Full Member level 3
Planet earth (most of the time)
I have a number of RJ45 connectors on a project, that are used either for serial communication or SPI. I cannot change the pinout. If the wrong device is plugged in to the wrong socket on the board, some bad connections can happen, and I am wondering how to protect against those conditions such as:
1. A Tx pin (-6v) on the board socket that might get connected to Ground pin of a device that is plugged in.
2. A pin on the board socket that supplies Vcc/3.3v to an external connected device, might get connected to Tx (-12v) of another external device (that is connected by mistake).
I can add protection elements either on the board or on the (cable of) the connected device, but can't change the pinouts.
Any solutions greatly appreciated
Thanks
embeddedlover
Full Member level 5
until and unless u connect ground and supply i don't think there will be any problem
If ur circuit draws high current then there is a chance that ur Tx pin when connected to supply may cause some damage
If at a pin u want to allow only certain level of voltage try to use zener to ground.
The zener rating must be your required vale.
If u want to eliminate reverse voltage try to use SR504 for reverse protection.
blapcb
Full Member level 3
Actually, there is no direct ground to ground connection, but the ground on the main board would connect to an interrupt (output) pin on a device being connected. So it would look like this:
Ground on connected device <--> Tx (-6v) from main board
Interrupt port on a chip on connected device <--> Ground on main board
So is that enough to constitute a ground connection and make a problem? Or does it have to be actual ground to actual ground.
embeddedlover
Full Member level 5
I don't think it would be enough and it is not preferable too.
U r trying to ground indirectly which may not work.
