Not a specific problem with your question, but I wonder why a large share of Edaboard posts is querying information, that can be found either by a board or google search? I need to operate the same search machines!Can you please provide the links for op amp based balancing circuits. I didn't find one.
How should it? By the way, Edaboard users can expect a schematic readable by eye. Simulation circuits are optional and particularly interesting for problems that need further analysis.I changed the circuit a little. Will this work?
Why? I fear, the problem is either reading or understanding electronics.I checked the link. It was not helpful.
Don't know, can't see it.I changed the circuit a little. Will this work?
Yes, it should it be at least supplemented with a complementary driver for every tap. The other problem is the "loose" of +/- 0.6 V caused by transistor Vbe. So with 12 V input, the individual capacitor voltages can vary between 1.8 and 3.0 V. You could add a single bias diode for each transistor pair, reducing the loose to +/- 0.3 V.I don't think the first circuit will work properly. There's nothing to balance the voltage between C2 and C3 or between C4 and C5.
You might have to rethink the idea of using opamps for this. Even with a current of 1 amp, it would take nearly an hour to charge/discharge one capacitor by 1 volt.The capacitors are rated 2.7 V 3000F
Yes, it looks very similar to the active balancing concept suggested in the Epcos application note. It can be extended to any number of cells.Can I use this circuit by extending the opamp stages to 6?
