Does the X.10 circuit can send signal to main(AC) line?
Taro
Full Member level 2
Does anyone have x.10 interface circuit? and or circuit that can send signal into main(AC) line? please suggest. thanks a lot.
TW523, 2way x10 module datasheet uploaded to FM, directory arturt134. This is version for 110V/60Hz. For 220V/50Hz try to search https://www.x10.org
Hi, arturt134.. good info...
I heard IEEE have plan to beat X-10 several years ago using Spread Spectrum technique...
But X-10 is free license (i think since March 1998)...
Oh yes. Patent rights has ended in 1998, if I remember, but "x10 powerhouse", producer of TW523, has not actualized TW523.pdf since 1997. In this document, on page 2 you see this words: "The X10 code format is patented" :smile:.
You can also check out the following site, it has a lot of schematics for the X10 modules along with some really great mods...
w*w.geocities.com/ido_bartana/
here is a good site, it has everything to build your own x-10 module, including the software an schematics, you can use it as reciver or as a two-way interfase to PC
Where is the site? :)
About X.10
You can search AN236. "X-10 Home Automation Using the PIC16F877A" in Microchip site.
Re: About X.10
What is in that technicalnote.pdf? *Sigh* .. don't have the points to download it :(
