It also means MSB last. So if you transmit 8N1 while setting the MSB high, then it is similar to 7N2.
The second stop bit won't be a problem for the receiver.
A problem could be if you want to receive 7N1 data stream with 8N1 setup.
But first read datasheet, be for trying some workarounds.
