Does OrCAD Pspice exist in Linux?
orcad linux
PSpice was once available in many forms including SUN work stations and Macintosh versions. As the sales of these other versions declined they were not continued. I suspect that the effort to port it over to another platform will not be done until that platform takes over at least half of the operating system market to the exclusion of windows at engineering companies. This is not likely because these companies will still need windows systems to run programs that only us it.
pspice for linux
Orcad is only for windows traditionally
linux orcad
Hello to all people,
>Does OrCAD Pspice as Linux software or is any plan to create such one?
Referring to OrCAD specific, this is true OrCAD is a Windoz Only program. :-((
But If we are talking about , generic schematic entry , PCB development and
simulation tool , there are a lot of projects , often free , that do that job.
try these links
www.geda.seul.org
They are not easy like OrCAD , but for medium sized design and with
a bit of patience they can be quite good and, give comparable results .
Enjoy to all friends ;-))
orcad pspice linux
maybe you can use wine + orcad under linux
linux pspice
No, big NO
pspice on linux
try hspice
orcad on linux
hspice is a different kind of animal, it doesn't have schematic capture
cadence orcad linux
For Linux, there is only Spectre to run simulation.
cadence orcad for linux
in linux
schematic -> ECS
spice -> hspice
but Pspsice & orcad for system level design not for ASIC design
I think use vmware/wine + linux can be use
or use dual partition for windows /linux ..
I ever use winXP + vmware (run linux hspice) it is ok
but I think use linux + vmware (windows) will better
orcad para linux
IN cadence ,there is a simulator for Hspice.
pspice+linux
it is defficult to run Eda in linux
I have not see or know there is anything software that can run in linux ,problemly there is no
but you should search in google
orcad pspice wine
Hallo!
On my former notebook I installed Linux and wine. Wine is a simulator for windows programms. I used pspice (MicroSim 8) and it works fine. BTW I only simulated circuits and did not make layouts. For layouting my designs I used a Eagle demo version.
