Does NI's SCADA have a PROFIBUS driver compatible with SIEMENS CP5611?
Moof
Full Member level 2
Argentina
Can i use national instrument to make a sacada with a cp 5611 profibus card?
I dont want to buy wincc to make it!!
scada profibus driver
I think that what he's asking is "Does NI's SCADA have a PROFIBUS driver compatible with SIEMENS CP5611?
You have other choices other tha WinCC, depending on the needsof your application. WinCC is a VERY complete system, may be you need something simpler.
¿Do you know the new version? WinCC Flexible.
I work at a SIEMENS automation distributor here in Argentina, in Bariloche.
Kind regards
Nahuel
cp 5611 siemens
Hi.
I need to do a simple aplication (10 tags only) and I don't want to buy WinCC.
The PLC is S5-95U.
Which options I have?
scada siemens
Hello Swilly,
Wincc is generally for S7 series PLC's. So a WinCC soft which has min. tags, 128. 10 tags may only be in mind :)
purchase wincc 6.0
Use any development software you're familiar with and who can work with DLL files. Then use Prodave (a dll files set) to communicate with S5 or S7 devices.
Good luck:D
scada pour siemens s7
With 10 tag, you can use VB for control & supervisory.
WinCC is sell by tag
siemens scada wincc
Hi all
I am trying to communicate Siemens S7 with Movicon SCADA... through Profibus DP... I am unable to do it. As per the procedure we need to set the Station Setting conguration for the CP5611 card through "NCM Manager wizard" which I am not able to find.... only after these settings are done I need to create a "Access Point" for the card which I will call from the SCADA... any one can help out....?
I am also attaching the steps required for configuration....
Currently i am communicating through MPI mode...
cp5611 compatible
Hi...you can use " Look-Out" scada programme of NI
scada movicon
Siemen s7 can communicate with Movicon software through OPC
ni scada
last project i do
between siemen S7 communicate with wizcon scada.
