Does IAR JLINK work with Keil MDK?
7rots51
keil with j-link
Does IAR JLink work with Keil C Compiler for ARM(uVision 3.5)?(for debug and programming)
jlink keil
HI
I think so , there is an option in the setup for using keil & Jlink - I will test it soon
And let you know.
All the best
bobi
keil j-link
In general yes **broken link removed**
....... however ....... if I would spend the money to buy Keil tools, I would add the money to have a ULink as well, just to make sure the two components have been thoroughly tested together.
Bob
iar jlink + keil
Hi
I have tested Keil & JLINK working together - OK
Both working well on keil MCBSTM32 evaluation board
You will need to do some setting in order to make it work well
All the best
Bobi
mcbstm32 j-link
From I test, JLINK can work with Keil Realview IDE 3.50. It have 2 options for select.
- RDI Interface Driver
- J-LINK/ J-TRACE
Or you use Cortex-m3, You can select Cortex-M3 J-LINK
