Re: HFSS-mesh promblem
yes, you can do dummy object approach described by loucy. You can force the surface/volume mesh parameters of either dummy or your source objects.
HFSS/Mesh Operations/Asign/On selection (surfaces)
HFSS/Mesh Operations/Asign/Inside selection (volumes)
This will bring menues where you can choose meshing parameters to force finer mesh but also you will be able to limit the maximum number od triangles/tetrahedra for a particular object.
This is the most you can do manually.
You can also specify some general parameters for the mesh during adaptive solver run in Analysis/Setup window.
flyhigh
