Register Log in
[SOLVED] does copper tape need grounding when sheilding plastic enclosure
Zak28
Advanced Member level 2
If employing a plastic enclosure for a noise sensitive board perhaps an audio preamp or other forms of preamps and using copper tape for sheilding, does the copper tape need to be grounded to the negative side of a dc power supply powering the circuit?
The tape would cover the entirety of all walls inside plastic box. The circuit only has 12v power supply powering it coming from panel mounted banana jacks onto walls of box.
BigBoss
Advanced Member level 5
Turkey
It helps to prevent the noise coming from external noise sources.
Reactions: Zak28
    Zak28
Zak28
Is it ineffective without grounding?
FvM
Super Moderator
Staff member
Bochum, Germany
Yes, without grounding mains hum and similar interferences won't be blocked.
Toggle Sidebar
Design Fast
