Does Cadence PKS is a good software?
drabos
Full Member level 6
cadence pks
Because we've just learned it. To my mind, better softwares must be exist!
what cadence pks do?
I have used PKS for 3 years .
It's good one .
it does Almost all thing as DC do ,.
it can also support sdc constraint format.
It's speed is fast .
    drabos
I have used PKS for one year and employ it to place, it is not bad.
But more people use PC. I don't compare them.
placement of SOC encounter is more powerful, PKS documents cadence release are less then before.
    drabos
if i am rgt PKS is mostly used only for synthesis, though it has other features of placement and routing...
correct me if i am wrong.
thanks,
Prasad
    drabos
ya.. he is right..
mostly PKS is used for logical optimization and inserting constraints..
we dont use place and route mostly..
Encounter is better tool for placement and routing. it is equally compared with astro..
SOC Encounter has inbuilt PKS , what is that ????
as we directly give netlist as a input while importing a design in SOC 4.1, though in 5.1 we can give verilog file as input.
reply soon.
Prasad
PKS was the first physical synthesis tool even before Physical Compiler (PC) and magma. The tool could do floorplan, some elementary power routing, full legal placement and global routing (all timing driven) in addition to RTL logic synthesis just like synopsys' DC. The 5.xx version had powerful datapath features like operator merging, complex arithemetic designware components (just like DC) and also power optimization features. However since the backend was done in a flat fashion in PKS, the size of the design (especially after half a million gates) constrained its usage. Realizing that most of the designs were going in the multimillion gates, Cadence introduced SOC encounter (this tool was called 'first encounter' before its purchase from Silicon Perspectives by Cadence). Cadence also decided to stop PKS since there was a lot of overlap between SOC-E and PKS. Basically SOC-E is much better in the back-end compared to PKS. The older versions 3.3, 3.4 were not good for timing driven optimizations (compared to PKS), so PKS was bundled into SOC-E so that the optimization rich features of PKS could be exploited by a designer in a opportunistic manner. Hope this helps.
Reactions: ivlsi
    drabos
    ivlsi
