Does anyone know of a humidity sensor?
PlatinumT
Member level 3
Arkansas
I was looking for a humidity sensor to make a circuit to monitor the humidity level in my computer case. Im sure there are some Im just having trouble finding one. I would really like one that had a analog output.
Thanks
Check sensirion's web site.It is very easy to use with common mcu's like Pic16F877 ;)
Analyzer.
yes, sensirion's /www.sensirion.com/ SHT-11 is a good choice it is combined temperature-humidity sensor.
Thanks alot! I just ordered a sample. One question though. Is the output an analog voltage or serial?
sensor
hi,
a paper about humidity sensor.
hope help you.
it's totally digital (= serial) !
you can find lots of examples on the net to attach it to your parallel port, or you can use some microcontroler of your choice to do the measure and the calcs !
sensiron using serial communication, 3 wire. i believe their humidty sensors can also measure temperature, which is a handy "all in one" feature. make sure you check the number of Tx/Rx bits per window to determine if you can use a microcontrollers on board serial communication pins.
sometimes these serial communication devices work on Odd numbers, like 17bits, and you have to write your own custom code to Tx/Rx. this is a very simple programming exercise.
an ANALOG temperature sensor can be ordered from w*w.microchip.com
i believe the part number is: TC620 or TC621
by connecting series resistors to these devices you can set the Hi/Low alarm settings of the temperature sensor. i know you wanted humidity sensor, but you should also do temperature. this is because humidty is greatly affected by temperature, so you need to have some sort of *temperature compensated* humidty measurement if you want any sort of accuracy. i do not know if microchip also makes analog humidty sensors. let me know if they do :)
Mr.Cool
honeywell
hi,
here is another humidity sensor from honeywell.
it has an analog output and works well.
greetings,
hqqh
