Docking Connector (Suggestion)
howie
Member level 2
Philippines
Anyone who can provide me datasheet of a Docking Station Connector, Male, Vertical Mounted, either through-hole or surface mounted with 30 pins (0.5mm pitch).
I already found one that was used in Apple I-pod but it has a 15-degree angle mounting. I need either vertical or horizontal mounted connectors.
You can refer to attached datasheet for reference.
Regards,
Howie
  • Dock Connector Male QV Series Foxconn.pdf
