Do you think the nested FSM is a good design?
EDA_hg81
Advanced Member level 2
Thanks.
vlsi_whiz
Full Member level 4
Penang
Well, that depends on the design. If you look at the PCI spec, you'd see that the arbitration scheme uses a nested state machine to service two levels of devices.
    EDA_hg81
Iouri
it is really depends what you trying to achieve, if you are concerning performance ie (speed) then no, if you are concerning code readability then it will help, also if you have a lot's of stages and speed is not an issue I would recommended to use small MCU something like 8051, or PICO blaze or MICO from lattice, also MCU, can take of a lot's other thinks in your design, just try to minimize processor-processor communication (if there are more then one) because multriprocessors system it is totally different world...
Good lack
    EDA_hg81
Black Jack
Full Member level 4
UKRAINE
Hi!
Don`t forget about illegal states of FSM.
In multy-FSM design this promlem more complex.
Good Luck
    EDA_hg81
EDA_hg81
Thank you all for your suggestions.
