Do you need to do post layout simulation for analog IC?
Gireesh
Newbie level 6
Post Layout Simulation
hi,
I want to know whther it is necessary to do post layout simulation for analog ic,if it has passed LVS checking?
Thanks in advance
Re: Post Layout Simulation
Gireesh said:
hi,
Thanks in advance
You must do it!!
Generally, parasitic component of Metal line (ex. Cap. Resistor) is not defined
in a library. In analog circuit, the parasitic make additional capacitor, resistor
(influence bandwidth and bias, crosstalk...).
The post simulation result might be not correct, it is the least method to prevent
teriible result for your chip.
If post layout simulation has not to be carried out, then where shpuld we consider the efferct of parasitic elements likr parasitic capacitors, resistors etc.
post lyt simulation are also done to see if there are any major timing variations ( rise time, fall time or propogation delays) due to the layout added parasitics, there should be less than 10% deviation, and its always better to do post lyt simulation to validate ur design again after lyt completion, as the LVS just tells u abt the interconnections.
Feedback loop is where you should pay attention to. e.g. amplifier compensation.
Another important is VCO in PLL.
it depends on 2 things:
one is the SPEC for the circuit, the accuracy and the speed;
the other is if the vendor can provide this the parasitics for this flow.
Yes, you have to do. Otherwise how will you know that your circuit will work after fabrication. Post layout simulation is the scale of mesuring the precision of your layout
Yes it is must to do the post layout simulation.
Because of ur layout being very neat it may not work properly as the parasitic in some path may increase.decrease the dalay on that path and the timings of the circuits and its response may effect.
another thing is the LVS only check the connectivity of the layout and dont give any info regarding the parasitic in any path so u must do the post layout simulation for checking its successful functioning.
