Do you know circuit with 7805 that increase the current??
xxtigerxx
Advanced Member level 1
Greece
7805 circuit
i want to increase the current from the regulator 7805 with the use
transistor. do you know any circuit?
national gives a circuit, it is in th pdf..
how to increase current in a circuit
If national gives a circuit for example, what is the question ?
7805 high current
You can add an external transistor to increae the output current. It is a very common circuit. I saw it from NS databook (> 10 years ago).
7805 increase current
I now saw the data sheet and understand your problem.
You can see an example of a "High Current Voltage Regulator" at the LM340 data sheet (Attached).
The data sheet also include an example of a "High Output Current, Short Circuit Protected" circuit.
Good luck,
Pazam
