Yes. I won't suggest other analogies rather than saying, if you try to use an analogy, you have to use a different one. A physically correct analogy respectively equivalence is possible in some cases, but of course doesn't simplify the calculation. If at all, I would do it the other way round, e.g. to analyse a fluidic or thermal problem with an electrical solver.you need to be careful to make sure any analogies are valid otherwise they simply cause more confusion
